Guest djchuck760 Posted April 10, 2014 Report Share Posted April 10, 2014 would i used the same blade that i would use for tinting or do i need a different blade for the plotter to cut the PPF film? thanks Link to comment Share on other sites More sharing options...
Ridler Posted April 10, 2014 Report Share Posted April 10, 2014 I use 60 degree blades for ppf and 25 for tint. Check out the guys at clean cut blades. They are extremely helpful and their blades are the best. I'm still on my first blade for tint after a year! Also, get yourself a couple extra blade holders for each blade that way you don't have to keep adjusting your blade height every time. Link to comment Share on other sites More sharing options...
Guest djchuck760 Posted April 10, 2014 Report Share Posted April 10, 2014 I use 60 degree blades for ppf and 25 for tint. Check out the guys at clean cut blades. They are extremely helpful and their blades are the best. I'm still on my first blade for tint after a year! Also, get yourself a couple extra blade holders for each blade that way you don't have to keep adjusting your blade height every time. yup thats what i wanted to do get extra blade holders sinze i hate wasting film and adjusting it since i have the tint set up the way i want it which is perfect thanks bro ill check them out Link to comment Share on other sites More sharing options...
Guest kccartint Posted April 11, 2014 Report Share Posted April 11, 2014 You can use a 30 degree for both in a pinch if you run out of blades but like Ridler said, getting an extra holder makes things much easier. I get about 3-4 months out of a blade at best but cut a lot of material. Tint tears through them faster then PPF. Link to comment Share on other sites More sharing options...
Devinswindowtint Posted April 11, 2014 Report Share Posted April 11, 2014 I have always used a 60° blade, but when it failed I only had a 45° on hand. Now I like the 45° better now. Link to comment Share on other sites More sharing options...
PPFdistributing Posted April 18, 2014 Report Share Posted April 18, 2014 for years we used a 60 degree and we cut around 40+ per day. Played around with a 45 degree last year and haven't turned back. Cuts smoother and more effectively. Buy a good blade as it will last you rather than trying to save $5-10 per blade and having it last a couple months. getting a separate blade holder is also a smart idea. That way you don't have to keep changing the depth and you can have separate plotters conditions for the different materials you need to cut. Link to comment Share on other sites More sharing options...
twotint Posted April 19, 2014 Report Share Posted April 19, 2014 I use a 45 for everything and like it. I have three blade holders set up for my Roland, tint, PPF, and vinyl. Now if all the PPF guys could get rid of the top sheets I wouldn't have to adjust from one brand to another! #Ihatetopsheets Link to comment Share on other sites More sharing options...
PPFdistributing Posted April 29, 2014 Report Share Posted April 29, 2014 Top sheet or not, you would have to adjust because all of the films have a slightly different thickness and if you want an accurate cut, you should have a dedicated blade and plotter setting for each film you use. Skipping steps like that will lead to problems in the end when just a simple setting change and a proper blade depth will reduce errors. Link to comment Share on other sites More sharing options...
Shadebyblade Posted May 25, 2014 Report Share Posted May 25, 2014 Just role yr top sheet off. Then plotte away.we neaver cut through them dull out blade t fast. Link to comment Share on other sites More sharing options...
PPFdistributing Posted June 4, 2014 Report Share Posted June 4, 2014 I wouldn't recommend stripping the cap sheet off before you cut. We do about 40-50 kits per day with the cap sheet on and the blade lasts about 6 months. If you are not doing that type of quantity, dulling the blade should not be a concern of yours. Dialing in the settings and making sure the film is running straight is your key components. Those who were never taught how to cut with the cap sheet on make poor assumptions on the features and benefits it has by keeping it on the film while you cut. Link to comment Share on other sites More sharing options...
