95 maxima
I tinted a 96 maxima middle last week and it gave me a fit,sat did 95 and its the same car but had no problems at all.One thing I read where some one dry shrinks by starting on the corners and I did on 96 but 95 did it from middle out and no problem as this is my normal procedure.I dont see where it makes a differance on the starting point,but I guess with me it does :dunno
Guest Litespeeds
It does matter where you start heat shrinking. After you have seperated your film into 4 quadrants, you need to start at one of the corners and work your way back to the middle but at small sections at a time. You might need to make about 5-10 passes on each quadrant to get the film to lay down totally flat before you start the next quadrant.
