compaq
Guest tintslut
OK, did you by some chance just format your drive , Install a new drive , or
remove a partition from your hard drive.
THE bios resides on a partition on your hard drive, not on board like a desktop.
Without knowing the exact model, I can only point you to compaq's
support site. Look for a utility that will let you access the bios.
OR try this. I assume this is a LAPTOP your are talking about.
Remove all battery packs from the battery bay and MultiBay, if applicable.
Disconnect the AC power.
Remove the real-time clock battery.
Wait five minutes.
Reconnect the AC power.
Restart the computer. During Power-On Self Test (POST), a ?162 System Options not set? message may appears.
Shut down the computer, then disconnect AC power again.
Replace the real-time clock battery.
Install the battery pack(s).
Restart the computer and now press F10 after you see the Compaq logo. This time, you should be able to access the BIOS."
    rxactlite.com
    rewiredtech.io
    2. 5
    3. 24
      llumar pinnacle...second installer visit upcoming!? bubbling/dust month later
    4. 24
    5. 24
    6. 24
    7. 24
    8. 24
    9. 24
