Guest Legendary Tinter Posted January 26, 2004 Report Share Posted January 26, 2004 Anyone know what bypass to use for a '03 aviator, (555f, u, or p?) Link to comment Share on other sites More sharing options...
Guest Legendary Tinter Posted January 26, 2004 Report Share Posted January 26, 2004 a dei remote start of course Link to comment Share on other sites More sharing options...
wndotint Posted January 27, 2004 Report Share Posted January 27, 2004 I think it's the 555p, but I don't use DEI, so I'm not sure. I know you can use the 555u and they give up a key, but no one around here likes that idea. Link to comment Share on other sites More sharing options...
Exact-Oh Posted January 30, 2004 Report Share Posted January 30, 2004 I just make them buy a blank transponder for $20 and follow the procedure to learn the code. No bypass module needed. Just a relay, an extra transponder, and a piece of wire. And, the only reason you need a relay is to bypass the unit during remote start only. If you want to disable it permanently, no relay is needed. PM me if you are interested in bypassing these without the use of a 555x module. It's a lot cheaper. Link to comment Share on other sites More sharing options...
Exact-Oh Posted January 31, 2004 Report Share Posted January 31, 2004 And to elaborate on that previous post, the only reason you need a relay is to bypass the security only during remote start. If you want to disable it permanently, you don't even need a relay. PM me if you are interested in more information on bypassing transponder systems without the use of a 555x module. It's a lot cheaper. Link to comment Share on other sites More sharing options...
tinterluigi Posted June 11, 2004 Report Share Posted June 11, 2004 If u r using DEI 555U is the only one that will work, and you will need to give up a key Link to comment Share on other sites More sharing options...
