MobileTintGuy Posted 14 hours ago Report Share Posted 14 hours ago How does the Gull wing system compare to the taping off and using the sausage packs for safety film. ? Link to comment Share on other sites More sharing options...
Tintguy1980 Posted 7 hours ago Report Share Posted 7 hours ago Both can be challenging; Gullwing already has the adhesive with a liner that needs to be removed and pressure applied to seat the adhesive with as few air pockets as possible. Any hiccups means a do over with each strip. Think about how it would look from the outside, not to mention the task of keeping it evenly aligned as you move along each strip. Practice makes progress, not perfection. I've got a few feet of white left over from my days in the industry and I can assure anyone will be challenged to install the stuff. What I have is predecessor of Gullwing and I cannot remember what they called it back then. ~~~~~~~~~~~~~~~~~~~ Dow995 structural sealant is akin to working with peanut butter; it can be messy, but once dry it has a much cleaner look to a Gullwing with air pockets trapped. Sealant can easily drip or contact unwanted surfaces, making clean up fun. ~~~~~~~~~~~~~~~~~~~ Either way, if there's any need for removal after a lengthy period of time, it could be work intensive to not do damage to the frame. Also, for both, you are best of waiting no less than one week film dry time (sun exposure and or warm and dry weather conditions) before applying any anchoring system, lest you find yourself with film lift in areas where the anchoring system was under stress to pull away. Here's a link for anyone who wants more info on Gullwing installation. https://windowfilm-staging.azurewebsites.net/commercial/bomb-blast-protection/mdico-gullwing-anchoring-system Dano and TintDude 2 Link to comment Share on other sites More sharing options...
