Are my standards to high?
Got a few quotes for my suv with tinters in a highly competitive area. I went with the highest rated/reviewed one by far with a median price quote and was a llumar installer. When I arrived, I was shown the llumar ceramic pinwheel  display. I was shown the ceramic level tint and impressed by it's heat rejection abilities and so I agreed to the ceramic and added the front two windows on as well. I dropped my suv off a half hour early for my appointment and left in my other suv . I was not rushing the installer at all. Before I left I went over that i wanted everything to the edge or over. I don't have dot matrix on any windows. I was told it would  be computer cut and it will be perfect.  He said he doesn't need to cut anything by hand. I brought the car in showroom clean anywhere near the windows. Gaskets and window tracks all around each window were clean, 99% isopropyl on all windows to perfection, every corner. I'm now on day 3.5 of the car unused baking in the tropical sun and I have imperfections that aren't going to clear up in 30 or 300 days. There is sand/grit between glass and tint at bottom of windows, a bubble bigger then a quarter, bubbles i don't think are coming out, wrinkles, creases and over cuts, a hair. I don't mind the tint overlapping the part you can't see that's a factory non dot matrix frame, but how can you let it under lap?  When I lived in NYC I used a guy called the art of tint and when he gave me my car back the worst I'd have is micro bubbles in the whole job. I contacted the tinter and he has offered to redo the job. My concern is that almost every window except for one has an issue.  If i let him redo them and they comes out as bad or worse now he is out double time and materials and I am out my initial investment time and extra inconvenience.  Is it fair to ask for 50% back for this relatively poor tint job by my standards? My standards are a tint job that's only flaw would be microbubbles. If I roll the dice on the redo where do I go after that? Any advice would be appreciated.
Dude, you are being ridiculous. If you have so much knowledge and high expectations, you should just try and do the job yourself and let’s see what type of results you have. You don’t even mention the type of vehicle that you have 🙄
Tinting Etiquette
Ignore what Clear Solutions has said above obviously not a professional himself !!!
From what you describe the install is a hack and not acceptable. However we can not be sure of the state of the imperfections without a photo to confirm.
What ever is fair is between the installer and yourself depending on how bad and what needs to be redone, its hard to comment again without seeing but it does not sound very good.
