TriCounty Mountie Posted December 14, 2020 Report Share Posted December 14, 2020 We are having a great deal of trouble removing Dusted Crystal graphic from the liner. It is not a complex or highly detailed cut. It continues to lift and in the end is damaging the edges as we try and get it to lay back down on the tape. That is assuming that it hasn't already torn. On the few that released the way we expected the premask is lifting the film as we try and roll it off during installation. We have done this type of install before and while encountering the odd issue have been able to install with no problem. I went so far as to look at a several installs online and we are not doing anything incorrect as far as I can tell. The only difference on line is the liner and premask in the videos come off very easily. Is this an issue with our supplier?? Any thoughts or feedback would be greatly appreciated, Thnaks Link to comment Share on other sites More sharing options...
That Canadian guy Posted August 12 Report Share Posted August 12 You are using the actual 3M dusted and the “blue”. 3M premask right? frosted crystal needs the “red” more aggressive pre mask….. it works with the dusted but is a bitch to get off unless left for 24 hrs. 20 plus years of struggling with 3M dusted and frosted - both products should be discontinued Link to comment Share on other sites More sharing options...
