Global Film- Private Tinter
14
Llumar window tinting
IS350 Recent Tint Job
Run your thumb nail across it inside and out -
I have a 2020 Subaru Forester Sport. A tint shop read the rear windows factory privacy film at 27.5%. I want to match this for the front windows, but the options I'm told are 20%, 22.5% or 35%. Given the light coming in from the windshield, I was told 22.5% would be the closest. Would you agree? 35% would be ceramic and they said looks darker than a non-ceramic 35%. -
8
14
Sorry about the down time
@Mdog glad to see you’re here. Hope all is well -
8
Scratches After Tinting
Okay, last response from me: Having worked side by side with a technician for seven years providing patterns for the library of one program out there, I would say someone scanned the pattern they received, leaving all cut edges and corners as they were OR the film was hand cut like a pattern maker has to do for a plotter library or a tinter not using a plotter. A good technician will clean up provided pattern cuts to the point of smooth rounded edges and they also smooth out long linear lines using the software like an artist to provide clean look around the entire pattern edge. In the process of cleaning up edges, the view is a pixelated (dotted) pattern edge that the technician shifts to or fro in their effort to provide a clean cut pattern that fits over and into the solid ceramic black border of auto glass. The film should not be cut short landing the film edge in the dotted transition area or the viewing area of the glass. A plotter will cut film similar to what you see when a house structure is built by 3D printer; no dips and valleys on long linear edges and no pointed corners UNLESS they were built into the design by the draftsman. Namaste -
8
I was able to take these at home tonight as well. From what I’ve read, there shouldn’t be wavy lines or jagged edges when a plotter is used. Would it be worth taking this to the owner to argue that a plotter was used?
