Really want llumar but can’t become a dealer in my town
14
Llumar window tinting
IS350 Recent Tint Job
Run your thumb nail across it inside and out -
I have a 2020 Subaru Forester Sport. A tint shop read the rear windows factory privacy film at 27.5%. I want to match this for the front windows, but the options I'm told are 20%, 22.5% or 35%. Given the light coming in from the windshield, I was told 22.5% would be the closest. Would you agree? 35% would be ceramic and they said looks darker than a non-ceramic 35%. -
8
