BigShubz Posted September 21, 2018 Report Share Posted September 21, 2018 Just recently iv been interested in shaving windows to get that factory edge look. So im wondering what do people use to shave i heard some people use 1" razor blades or carbon blades. also how would you shave windows where you cant access the side edge of the window because of the inner side seal being bigger. i bottom load and seen some videos on youtube where people leave a bit of overhang and squeegee out the window roll it up before shaving and squeegee out the bottom half then roll the window down again to shave. My question is how is this possible as this would lead to the top of window peeling because of the overhang. Link to comment Share on other sites More sharing options...
Jkatfelix Posted September 21, 2018 Report Share Posted September 21, 2018 either use a small file or learn to shave with an olfa blade..i usually heat up the window with a torch squeeze out the water and then hit it with my blade quality tintz 1 Link to comment Share on other sites More sharing options...
quality tintz Posted September 22, 2018 Report Share Posted September 22, 2018 16 hours ago, BigShubz said: Just recently iv been interested in shaving windows to get that factory edge look. So im wondering what do people use to shave i heard some people use 1" razor blades or carbon blades. also how would you shave windows where you cant access the side edge of the window because of the inner side seal being bigger. i bottom load and seen some videos on youtube where people leave a bit of overhang and squeegee out the window roll it up before shaving and squeegee out the bottom half then roll the window down again to shave. My question is how is this possible as this would lead to the top of window peeling because of the overhang. Some people cut Corner short so they don't have to get deep in the corners and when they roll it up I think the overhang is very very little so it doesn't grab junk Link to comment Share on other sites More sharing options...
drtint Posted September 23, 2018 Report Share Posted September 23, 2018 I use the 30 degree olfa blades and run them into the corner sil quality tintz 1 Link to comment Share on other sites More sharing options...
Tint Slayer Posted September 23, 2018 Report Share Posted September 23, 2018 If you have 1/8" extra on each vertical side you can make your top 2 edge radius just slightly bigger than 1/8", so when you place the film you look at the top 2 corners and line them up so you can easily start shaving where the film goes from above to below the glass edge and also where that intersection meets right at the rubber. Link to comment Share on other sites More sharing options...
