1 ply 1 mil Lifetime Warranty
Film Handler 72" $500
Film Handler, very lightly used, comes with shims. $500 Coopersburg. PA Text: 6102166437 -
14
Llumar window tinting
IS350 Recent Tint Job
Run your thumb nail across it inside and out -
I have a 2020 Subaru Forester Sport. A tint shop read the rear windows factory privacy film at 27.5%. I want to match this for the front windows, but the options I'm told are 20%, 22.5% or 35%. Given the light coming in from the windshield, I was told 22.5% would be the closest. Would you agree? 35% would be ceramic and they said looks darker than a non-ceramic 35%. -
8
14
