Posted
I have been doing tint for awhile, but I am having trouble with this. I have brand new Northstar windows that I am tinting for a customer.
I clean & clean & clean spray & sqweeze,  cut my pattern , spray the window 1 last time install the film & guess what I still get dirt
around the edges. Is it possible that the spray is drawning dirt out from around the window seal? Any suggestions?
Thanks
Posted
Are you spraying on the glass down the sides of the window to flush? If you are hitting the frame, you found the problem
Posted (edited)
Thanks
Tap water ?? what solution are you using and how much are you putting ?? Are you using scrubby or razor blade?? Are you taping hairy side seals??? Explain more !!!
Edited by quality tintz
