tint sticking
Posted
i recently started using Suntek standard, carbon, & high performance. Tint shrinks well, but is giving me major problems sticking. I use a soap bar (ivory). I have tried dryer sheets, it stuck even worse. Any ideas???
  • Replies 24
Posted
Not sure about Suntek ? Never used it. BUT....
How bout a brief description of your prep process. How much are you putting on the glass? How big of a dryer sheet piece are you using,,, etc,etc.. Thanks. :thumb
Posted
I am using a soap bar (ivory). Im putting a moderate amount on and letting it dry. I ve been tinting for over 25yrs and have used fabric softener, and a soap bar. soap bar is the best in my opinion. Its only been sticking since i went with Suntek. Suntek shrinks awesome and is a very good film. Im just curious if anyone else is having this issue with Suntek, and if so what are they doing about this sticking problem?
Posted
With suntek you dont want too much slip or youll having tacking problems, especially if the bg has thick defroster lines. Maybe have separate slip for the bg and dont use dish soap for slip if you are.
Posted
I think the OP is talking about it sticking to the outside of the backglass while shrinking(not floating enough). :thumb
