2017 Hyundai Elantra heads up
Tiger Tint
Posted
They have a quarter window again but they are very easy. The bg is just like the newer sonatas with an even easier shrink. I pulled the panels, it's just one screw in the door pull. The only thing to watch out for if you pull panels is the sail panels on the front doors. You have to pop it loose then pull straight out from each side. If you pull It up or down it will break the plastic clip in the center of the sail panel. It's an easy fix with some super glue but I definitely won't break one again lol hopefully this saves someone the hassle in the future.
Posted
screw pulling the panels.  just remove one phillips head screw from behind the door handle and pop the top of the panel loose.  sweeps pull super easy.  dont make it harder on yourself than it has to be.  to lay the back seats down for easier install on BG, open the truck and there is a black latch on each side.  pull those two and seat latches release.  this car is super easy to tint.
