Benefits of Factory Tint
Posted
I know that factory tint offers little to no benefits but i would like to see some actual specs on UV rejection and Heat rejection. I want to be able to factually explain the limited benefits to my customers.
Anyone have this info?
  • Replies 24
Posted
Back when EDTM released their SS2450 meter I took it around to car lots measuring factory glass performance, both clear and privacy.
Sorry to inform but glass mannies have vastly improved glass performance both architecturally and in automotive. Most privacy glass today have Tset in to low teens with 95-98% UV reduction. I measured the fronts on many vehicles and found the best to be on a Cadillac with Tset in the mid-40's and UV reduction at 95%. All numbers taken by the SS2450 were real eye openers. And, none of the glass measured was laminated.
These type numbers have been in play since 2008 and you can find performance values at Pilkington Automotive and Saint Gobain Automotive sites. You'll have to dig deep to find them.
Edit: There is no disputing the finding of the EDTM meter discussed here as it has been proven to be accurate to within 2% when compared to readings gathered using a $100K+ spectrophotometer.
Posted
Many many threads here talk of Olfa blades changing in the past few years. These complaints follow the same timeline that glass mfrs stepped up the technology that is put into auto and flat glass, due to EPA and energy requirements in the construction world. Today's glass is incredibly efficient and adding film in many cases .. Is not a significant improvement from a ROI standpoint.
Posted
TomT you might have a good point :twocents
Couple years ago I went on the Subaru forum to find out a answer for just what Smartie confirmed. Also found that Subaru went to framed windows because they could still save weight by making the glass lighter with the frame. Smartie can you confirm this?
Cheers
Posted
Well we should keep this info to ourselves. Alot of SUVS still need tint on back half =)  More money for us
:yeah
:yeah even if it is better I ain't telling the customer that.
:ditto
