Air bubbles?
Posted
Need a little advice not sure exactly what may be going on I have had a few vehicles that after about a week of curing there are small air bubbles left behind. These are completely hollow no contamination in them. I was using the same source of water that I always have, but did put an additional filter for more filtration. Finally I have just switched to straight distilled water, and so far so good. I clean my bottles daily to eliminate buildup. These are not present at the time of install just after curing. Any info is appreciatedef10a934afb2f31220b8c29f416ea59e.jpg
Posted
My guess is you're leaving a bit too much water under the film.
:yeah I would have to agree. Or contamination in the solution.
Good to hear from you TintCracker. Cheers :beer
Posted
Using j&j. I got a new bottle and quit using old bottle of j&j . Also I use a blue max on a fusion handle and squeegee usually two to three passes. Also using global classic black.
