1969 Mustang Coupe back glass
r91488
Posted
Has anyone ever done a the back glass on a 69 Mustang? Does it need to be heat shrunk? It doesn't seem to be too much of a curve, any experience would be appreciated. The glass is out of the car and was thinking it may be better to tint it prior to installation.
Posted
^^^^ :yeah  ^^^  Any window set into rubber gaskets is easier to get a better finish if its tinted while its pulled IMO.
Posted
I was thinking the exact same thing, I am concerned with having to heat shrink it. I guess I can get it going and if I start to get some "fingers" I can attempt to use the heat gun then. How long would you wait for the tint to dry/cure before putting the gasket and installing the window? I will most likely need to use a suction cup to bring the window in as I pulling the lip of the gasket over the metal. Thanks
Robert
