06 F150 door panel
Tiger Tint
Posted
Has anyone removed the panels on one of these? I removed two bolts at the bottom of the panel, two behind the door handle and one under the window switches but when I went to slide it up off the gasket it wouldn't budge. I didn't want to break anything so I just tinted it with the panels on. Am I missing a bolt or something? Do you have to remove the door speaker? Thanks in advance for any advice!
Posted
Yeah if anything else take out the screw behind the door panel and pull the sweep. Videos on YouTube though If needed.
Posted
Do you pull straight out? This is one of those panels that doesn't have plastic clips. It's supposed to lift straight up off the door.
Posted
Get a hook tool. Usually comes in a set of four. It's a little aggravating but start at the front towards the mirror it should come right out. You'll have to pry back on the top of the panel a little.
Posted
Sorry I shoulda been clearer, do you pull straight out on the top of the door panel? or do you have to push up on the panel first? I just don't wanna break one of those hooks behind the panel.
Posted
You're not going to break anything. Just take that one screw out and pry back on the top. That plastic on the top has a lot of give in it.
