Kia Sorento 2016
Devil with bad attitude
Posted
When you look at these trims specially around the door lock grab handle from inside, you wonder how on earth is that attached?
Is there a typical screw in behind it? No!
One screw hidden way underneath the arm rest on all doors with a plastic cover that hides the screw.
Take that out and unclip all the male/female door trims plugs and its off and then the internal weather strip can be freed.
Tape the verticals due to felt and its done.
Simple rear screen but the wiper arm doesn't sit up out of the way which is a bit annoying.
Devil
Posted
hmm,, your model has felt?, I did a set of fronts yesterday and the verticals had no felt.
Posted
Same here
