Infiniti G37 Coupe Question
DynamicATL
Posted
We have done hundreds of G37 coupes without any issue.  However on this one we are having issues with the film being pulled up in the corner with the windows moves up/door when opening door.  It will be coming back for the 2nd time after the initial install for the same issue.  This last time we let the car sit with the doors open and clamped for couple of extra hours.  Wanted to see if anyone else has had this issue.
Posted
I had to redo. Buddy's car twice for this very reason, a hard chunk of rubber near the mirror on both sides eventually worked it loose. Once I figured out how easy the sweeps come out I got it taken care of.
Posted
Thanks, actually doing it right now. Pulling seals. Thanks
How'd the install go?
Good, easy to pull the seal.  We will do it from now on just in case.
