Marine Window Tinting
Posted
I called my rep from global and he said the hp film is the worst because of the metal in the film and that there is not a film for marine application.
any feedback?
what film are you guys using for marine?
I know there is not a lot of marine tinting occurring but any thoughts or past experience.
Thanks
Posted
The marine environment is going to be more harsh on films. When dealing with a marine application, the use of a metalized film can produce corrosion in the film. I agree with Dynamic, it would be advisable to use a sealant if using a metalyzed film. I would suggest a good Color Stable Non-Reflective 2ply film.
Posted
ok.. ya its all freshwater around here. no salt.. plus if people are spending $100,000 to $200,000 on boats.. i would hope that they are keeping it out of the weather/sun..
Any Should/will be fine with freshwater boats,,I haven't had any issues
 thats what i gathered from some info i received from global...but obviously there's no warranty on it because they cannot guarantee it.
Posted
what type of sealant?
Posted
One other thing to consider is if these are big boats, seeing they are $100,000-$200,000 boats, is will a metalized film mess with the gyroscopes and other instruments in the boats? This I do not have an answer for and something to consider.
Posted
You could use a non-acetic(non-corrosive) silicone sealant, unless Dynamic or someone else would have a better suggestion?
Posted
there really not big boats.. just really expensive.. one boat is only 3 30"x 40" and the second boat is 5 panels with the added 2 20"x40" side panels...just simple malibu boats.. I did think of the metalized film messing with gyroscopes/instruments.
Posted
You could use a non-acetic silicone sealant, unless Dynamic or someone else would have a better suggestion?
just a normal sealant from hope depot or something
