2015 Cadillac CTS installation tips
niagaratinting
Posted
Tips for tinting the 2015 Cadillac CTS
1. hold start button 10 sec to go into service mode (power stays on)
2. sweeps removable, remove 7mm behind handle, pry top of panel back from 5 horizontal clips (2 flat screwdrivers or prying tools work good), pull sweep out. Window down when installing sweeps.
3. lubrication on glass from seals removable with rubbing alcohol.
4. rear headrests pullout with seat backs forward.
5. side panels press against back glass, not a lot of play with width of back glass, when forming try not to cut past matrix much (1mm)
6. lower heater lines retained water where heat formed (bad on freezing days)
