2011 BMW 323
TintWizard
Posted
Any issues with this car ? Panel removal ? Does it need felt ? Any other things to be aware of ?
Posted
I've only done the 328. Appears the panels may be the same though. Not sure if you had to remove them I did though because it was an r&r. Brake light had a matrix around it so I left it out.
Posted
I guess I mainly just fishing to see if I have to take off the panels in order to felt so I know how to price it accordingly
Posted
I assumed he ment E92(coupé) since he mentioned if it needed felt, my bad. If E90, easy to remove panel.
E92 has the big ass dot matrix on top of backglass that needs either vinyl over, or tint over, let the film dry a bit, pull down to where the dot matrix ends and put glue on, then apply film again.
Edit: I didnt use felt on the E92s I have tinted. Just sanded down the dotmatrix on the side fronts, so the film would stick better. First E92 I put film on it would tear up in the top corner. Sanded second time, no problem  :thumb
post-36832-0-92148100-1454789511_thumb.j
