71' Toyota Lancruiser
Posted
Need help with the rear corner windows. Tried 2 piecing them with a vertical splice and installing in one piece with no luck. Im thinking doing it in 2-3 pieces horizontally. What do you guys think?
post-23486-0-39234700-1454463703_thumb.j
post-23486-0-94067800-1454464317_thumb.j
Posted
like over lord said gotta pull em out pj, shrink is easy if I remmebr correct laying them on the inside they want to pull away in the middle, but a little heat on the outside does the trick , pull em out for a good install
Posted
there not that bad to pull out just make sure seals aren't dry rotted because it can rip when you pull out , I believe those have a lockinstrip in the center of moulding
