Will this go away over time?
Posted
I had tint installed a couple of days ago and I was wondering if you guys could please tell me if that blemish at the corner of the dot matrix will go away over time or if it's going to stay that way.
  • Replies 68
Posted
Run your finger over it. It'll probably lay down. Check again in a few days. Sometimes it will if it hasn't been to long.
Posted
I thought about doing that but didn't want to risk messing something up.  I went ahead and did it and it looks a lot better.  Not perfect, but I can live with it if it stays as is.
Thanks.  :thumb
Posted
Yeah, just gently run your finger along it to lay it down.  If pops back up, you can take it back to the shop and they can heat it up and press it out.
So even if it does pop back up it can be fixed without much difficulty.  Good to know. Thanks.
Posted
Like dynamic said if it comes back within a day or two they could probably heat it up some and get it to lay properly. I've had some lay and no more problems and others that just keep coming back.
Posted
Looks like maybe a fiber. Probably heat and chizzle would get it to be not as noticeable. Shouldn't be to bad for a shop to fix.
Posted
I couldn't fix the crescent tonight as the sharp angle of the glass towards the bottom, the low light level, and condensation on the glass made it pretty difficult to see what I was doing.
I'll give it another shot tomorrow morning.
