2016 Toureg Any tips??
TintOhio
Posted
Easy car, don't put too much pressure cutting on the rear quarters if you hand cut.  Mark it and cut outside.
Posted
Hey there TintOhio,
It might just be me, but I found the VW Toureg to be a bit of a pain.
The rubbers on the door glass are tight, and you will need to tape up the felt. I am sure like me you don't want gaps, so I recommend flushing the edges of the wind ups with a soapy mix so that the film doesn't get caught and suck in contamination when positioning.
I really hope this helps.
Cheer
Posted
I found the back doors to be a real pain because the rubbers were so tight. I ended up pulling the side rubbers out so that I could position the tint without picking up so many contaminants.
