Guest vital Posted March 22, 2004 Report Share Posted March 22, 2004 when you do passenger and driver side windows, do you lay the film on the outside and then cut along the bottom rubber to get your two halves of film for each window? I always did this but today a customer complained that his rubber was cut and wanted a refund... I'm thinking of using a scissor to get the half instead now. how does everyone else cut their film near the bottom rubber? Link to comment Share on other sites More sharing options...
Devil with bad attitude Posted March 22, 2004 Report Share Posted March 22, 2004 Unfortunately Vital you are done like a dinner on this one. Cop the replacement cost for the new item but not a full refund. My technique is totally different to most because I use liner patterns retrieved to make future templates on the bench where I cut the film there. Devil Link to comment Share on other sites More sharing options...
BIG E Posted March 22, 2004 Report Share Posted March 22, 2004 Got to be careful, a cut rubber is not good! Link to comment Share on other sites More sharing options...
Guest vital Posted March 22, 2004 Report Share Posted March 22, 2004 I was trained to cut along the rubber area but unfortunately I wasn't trained very well and had to learn a lot of the stuff myself, thanks to this site Link to comment Share on other sites More sharing options...
TintWizard Posted March 22, 2004 Report Share Posted March 22, 2004 Use the factory edge of the film and line it up with a 1/4" overlap for your bottom...then yourknife won't be needed down there or just "score it wit hyour knife cutind through only the 1 layer of film and finish the cut on a glass hanging on your shop wall Link to comment Share on other sites More sharing options...
Mr paladin Posted March 22, 2004 Report Share Posted March 22, 2004 Use the factory edge of the film and line it up with a 1/4" overlap for your bottom...then yourknife won't be needed down there Good advice Link to comment Share on other sites More sharing options...
Guest Eclipse Posted March 22, 2004 Report Share Posted March 22, 2004 TintWizardPosted on Mar 22 2004, 04:42 AM ? Use the factory edge of the film and line it up with a 1/4" overlap for your bottom...then yourknife won't be needed down there We do it the same way. Link to comment Share on other sites More sharing options...
VWaholic Posted March 22, 2004 Report Share Posted March 22, 2004 This is one reason we use the Plotter Cutter. We don't have to worry about cutting rubber any more. TintWizard gave the advice to use on this one. Link to comment Share on other sites More sharing options...
Tintcutter Posted March 22, 2004 Report Share Posted March 22, 2004 Tinttek! Now I can sleep at the office not worrying about tinters with knives on cars. Link to comment Share on other sites More sharing options...
Protint Posted March 22, 2004 Report Share Posted March 22, 2004 Butt the factory edge up on the bottom rubber cut the sides, roll it down and cut the top edge of the glass. If you do it this way you will get a perfect cut every time and not have to worry about re-cutting your windows due to computer inperfections. Link to comment Share on other sites More sharing options...
