Pug 206 Rear Screen
Guest PnkDesigns
Guest PnkDesigns
Finding the rear screen of a 206 quite difficult in the bottom left and right hand corners. Tops not that much of a problem...
Anybody have any good tips for these or techniques?
I have been dry shrinking with powder and then wet after, im getting closer each time just dont want to keep throwing away material...
Thanks
Lee
Guest PnkDesigns
Ok mate, yes it curves alot in the bottom left and right hand corners, when I anchor down the sides it produces a big load of vinyl, somewhat makes it worse once ive anchored down the sides?
Put your anchor low about 3/4 demister line, use soap method an lift an pull, I dont anchor sides.
If you crease buttom or top leave leave big when cutting an move film either up or down to take crease out of window.
Hope this is of help.
