2013 VW Passatt Door Panels
KonSiva
Pop the silver trim piece off and there is a torq bolt towards the rear of the panel. It is very tight and will sound like it breaks when you pop the trim off.
However, you CAN just lift the top edge of the panel out from the upper belt molding (gasket) and then remove it. No need to fully remove the panel. Those gaskets sort of lock on the door frame and you can't just pull them straight out. You have to tilt them inwards a tad, then they come out easily.
Also do yourself a favor and pull the rear deck out. It will make life easy and those quarter windows will come out clean too. Just be careful of the push-pins holding the deck in. Those actually thread so use the correct allen size and unscrew or they WILL break.
Guest esttint
2013 passat is just a facelift and is same like 2005 passat
door panel remove is for making tint job easier, quality much better. So it makes very good sense :)
