Slip for Oracal 8300
Hello all. This is my first post in this forum. I hope to be helpful.
I use a mixture of 80% water and 20% glass cleaner. Definitely works better than water-soap solution for me.
I've been doing a good amount of 8300 on tail & headlights recently. Definitely get/use a steamer (you will be amazed how well the film takes the wet heat versus dry heat from a heatgun). As for slip:
1 spray bottle of very hot water (trigger sprayer)
1 tiny, small, drop of Baby shampoo
The film will lay down with just water very well, the only thing is if you miss a small amount of water somewhere squeegeing out, your done, ha that water isn't goin no where. So the 1 drop just allows you a bit more forgiving install.
