Devil with bad attitude Posted September 9, 2012 Report Share Posted September 9, 2012 Ok to do, rubbers lift out but are the rear doors hard to get the trim back in place? Suggest a bit of soap on the rubber to ease the top of the trim over and into the seal's groove. Rear screen in the top corners prone to heat creasing because it bends both ways and a lot to ask of a film to comply. devil Link to comment Share on other sites More sharing options...
Devil with bad attitude Posted December 4, 2012 Author Report Share Posted December 4, 2012 Just an update on this car after doing a few more...2 screws per door, take the trim off as it is much easier to pull the rubber out. Great to do in quick time. Trick with the rear door is that the one screw you can't see is at the bottom of the door grip hidden under a rubber cover gasket that is so well concealed. devil Link to comment Share on other sites More sharing options...
Glass Tinting Supplies Posted December 4, 2012 Report Share Posted December 4, 2012 I am loving almost any hyundai.. If I was brave enough to take on dealership work again, I would go and see my local Hyundai guys.. I am still yet to do a veloster, are these easy to do as well Dev?. They look a fancy? Link to comment Share on other sites More sharing options...
