Suntek cxp 80%
Does it block heat as the ceramic one?
The focus should be the ability to block heat at higher temperature. Let's not think about meter reading and use real heat reduction comparison under heat lamp. Trust your skin, I don't think you will feel very comfortable with CXP under the heat lamp.
In this aspect, Ceramic or IR film will outperform CXP because most of them clocks >90% infrared reduction at high temperatures (wavelength >1800nm) while CXP can only manage about
    rxactlite.com
    rewiredtech.io
    2. 9
      Window Tint Installer looking to relocate for work
    4. 3
    5. 2
    6. 3
    7. 1
    8. 2
