Do you see any issues with this install.
I guess you mean the trapped air when the pane is slid open..... :hmmm
The heat on the first DP that the other window is now behind is my concern, the TSA on the window that is now covered by the other is very high as now the heat has no way of escaping, more then if you would have dark wooden blinds over the windows.......... :blink
Good point. But in my experience (limited yes) most people have their windows closed during colder months. With a south facing window that would be when the harshest exposure would be on that surface. Chances are those windows would be closed.
My thoughts, wrong as they may be, are that in areas that actually have a winter this wouldn't present "too much" of a problem. But in more southern areas where open windows are more likely in during the months of southern exposure this could present more of a problem. But it only takes one good day to break a window I suppose. :dunno:twocents
Maybe a light film installed on just the fixed pane would be the ideal solution, if the window would be opened more than half of the time. :dunno
