Guest musicmankeb Posted August 12, 2012 Report Share Posted August 12, 2012 So I've had problems with the glass scratching on the outside because the previous owner lived near the beach and had sand in the felt. So I was driving the other day and noticed when I looked out my driver side window that things were blurry. I compared this to my passenger window and the passenger side seems fine. I thought it was my glass because it's a little scratched on the outside so I spread some soap on the outside of the window and along the felt and rubbed my fingers along the felt to clean it and sprayed water down through the felt with the window down. I dryed my window and sat back inside and still noticed the same problem still. Upon further inspection, I noticed that the tint is starting to do like an orange peel pattern and make it hard to see out of the window clearly. Has anyone experienced this? The film is from the marathon series - 20%. I also still have the roll # as well. I've had the film on for about 2 years and purchased it around that time too. Link to comment Share on other sites More sharing options...
McCoyH Posted August 12, 2012 Report Share Posted August 12, 2012 When were the windows tinted. Link to comment Share on other sites More sharing options...
Guest musicmankeb Posted August 12, 2012 Report Share Posted August 12, 2012 I said that in the first post, 2 years ago. Link to comment Share on other sites More sharing options...
McCoyH Posted August 12, 2012 Report Share Posted August 12, 2012 Just read that, sorry. Link to comment Share on other sites More sharing options...
coast2coasttinting Posted August 12, 2012 Report Share Posted August 12, 2012 I have been installing that same film for over 2 years with no issue's. Could just be a bad piece of film but I would think the whole job would look this way. or atleast the whole side would be turning the same way. Since it is just the 1 window it might be in the glass itself. Is the door glass laminate by any chance? Link to comment Share on other sites More sharing options...
Guest musicmankeb Posted August 12, 2012 Report Share Posted August 12, 2012 I don't think so, it's a 2005 mazda tribute. It's just that one window which is wierd. I have not sprayed any cleaners on or changed anything so I'm not sure why it's shown up now all of a sudden. The only thing I can think of is that it's the side that gets the most sun. The driver side rear door window was tinted from the factory and then I put 10% on but I did that maybe a year ago and that was a different line of film. So the only thing I can compare it to is the passenger side front. To give you an idea of my setup. I have 20% JWF Marathon on the two front windows and were done 2 years ago. Everything else has factory tint on it plus 10% JWF Greystone and was done 1 year ago. Link to comment Share on other sites More sharing options...
coast2coasttinting Posted August 12, 2012 Report Share Posted August 12, 2012 it could be that the window does get more sunlight then the passenger side window. Did you install the film yourself? Link to comment Share on other sites More sharing options...
Guest musicmankeb Posted August 12, 2012 Report Share Posted August 12, 2012 Yes I did the install, I know what I'm doing though for the most part. It's not my first car! lol Link to comment Share on other sites More sharing options...
coast2coasttinting Posted August 12, 2012 Report Share Posted August 12, 2012 what squeegee did you use to install the film? Link to comment Share on other sites More sharing options...
