compu cut users
Guest DixieGraphics
I don't think you can upload your own images. you might can call customer service and email them whatever it is and let them post it for you, but then you'll be sharing the graphic.
it would be easier to use another program if you have it
Guest Film Maverick
The cheapest format is Corel Draw which you can pick up for about $250. The most sophisticated is Adobe Illustrator and there is another that Bekaert sells that I have only heard about. You can pull the image off the web as long as it is in a couple different common formats (as S & S said). Copy the pic, pull it to the program you are running, trace it out, discard the original pic, put the traced program into Computer Cut, Cut out the peice.
    rewiredtech.io
    Thank you for donating to
    TintDude.com
      Under hood paint repair after Xpel removal--opinion on my idea requested.
    2. 2
      Crystalline VLT question
      Optimal environment temp
    4. 1
    5. 2
    6. 2
    7. 8
    8. 8
    9. 0
      Any LLUMAR or XPEL Dealers?
    10. 7
      llumar backer branding
