rickwitap Posted November 17, 2010 Report Posted November 17, 2010 Having problems with my Anagraph not working with Precision Cut. I have the firmware installed but nothing happens when I go to cut a pattern. Precision Cut shows that the pattern was cut, but it seems like the information is not being sent to the plotter. Anyone have any suggestions?
Slick Posted November 17, 2010 Report Posted November 17, 2010 are you just setting this up? or did it just stop working?
rickwitap Posted November 17, 2010 Author Report Posted November 17, 2010 I am setting it up for the first time.
Slick Posted November 17, 2010 Report Posted November 17, 2010 serial or parallel port? and do you have the right cable? I had one hooked up to a printer port once and had the wrong cable...
Guest scottydosnntkno Posted November 17, 2010 Report Posted November 17, 2010 did you install the drivers properly? you have to have the right com settings and all that jazz
rickwitap Posted November 17, 2010 Author Report Posted November 17, 2010 I followed the instruction on the APD CD that came with it.
addicted to tint Posted November 17, 2010 Report Posted November 17, 2010 Having problems with my Anagraph not working with Precision Cut. I have the firmware installed but nothing happens when I go to cut a pattern. Precision Cut shows that the pattern was cut, but it seems like the information is not being sent to the plotter. Anyone have any suggestions? Call Melvin at Precision Cut and he'll walk you through it.
Guest tintmax Posted November 17, 2010 Report Posted November 17, 2010 Yes, Melvin is a big help with all Precision Cut and plotter needs.
watchdaride Posted November 1, 2011 Report Posted November 1, 2011 i use precision cut and anagraph. You have to use the serial port .
