need help deciding
Guest hemiram
Guest hemiram
Hello. I have a 2004 Dodge Ram Quad Cab. The rear door windows are factory tinted. I wan to get back glass and front door windows tinted. I don't want it real dark. I also want it to match up well. There's two tint shops I'm considering. One uses llumar and the other uses suntek. Which is best?
  • Replies 24
Go look at the work they do, and then decide, both good films, but a bad install will make you regret the use of any film, no matter how good. Make sure you check the top, and sides, don't want light gaps/uneven cuts. Good luck!
Guest Litespeeds
Like Tintboy said, check out their work to see which one is better. Both films are good but they also have a cheaper line. Make sure it is the Llumastar ATR Charcoal or the Suntek HP Charcoal films and you will be just fine.
