finishlineautosports Posted October 23, 2010 Report Share Posted October 23, 2010 Is this the correct glue to use for dot matrix areas? Also, how wide should the bead be on average? I just don't want to use too much. I'm going to try it on an 06' Altima today. Link to comment Share on other sites More sharing options...
Guest Total tint Posted October 23, 2010 Report Share Posted October 23, 2010 get a elmers glue stick Link to comment Share on other sites More sharing options...
Guest tintjam65 Posted October 23, 2010 Report Share Posted October 23, 2010 Is this the correct glue to use for dot matrix areas? Also, how wide should the bead be on average? I just don't want to use too much. I'm going to try it on an 06' Altima today. Yes. Link to comment Share on other sites More sharing options...
addicted to tint Posted October 23, 2010 Report Share Posted October 23, 2010 Is this the correct glue to use for dot matrix areas? Also, how wide should the bead be on average? I just don't want to use too much. I'm going to try it on an 06' Altima today. The 06 altima has about an inch or more matrix band at the top of rear glass - so very lttle. In fact you see most of them left alone and they dry with a uniform band. Link to comment Share on other sites More sharing options...
finishlineautosports Posted October 23, 2010 Author Report Share Posted October 23, 2010 Yeah, no glue was necessary on that BG...Piece of cake car...Hardest part was getting behind that 3rd brake light. If I was quicker at shrinking, probably an 1hr. to 1hr 30min vehicle. Link to comment Share on other sites More sharing options...
Guest Voide Posted October 24, 2010 Report Share Posted October 24, 2010 Errr....If I remember correctly, the Altima has a 1-2 inch dot matrix that, if not glued, looks like complete ass when dried. Edit - We glue our Altima BG's; customer is happier more often than not. Just run a small bead and you'll be fine. Link to comment Share on other sites More sharing options...
finishlineautosports Posted October 24, 2010 Author Report Share Posted October 24, 2010 It's not even one inch....Tiny! Link to comment Share on other sites More sharing options...
