Rapid Tac Dot Matrix Concensus?
Guest scottydosnntkno
we're talking about the big matrix at the top.
I never use rapid tack in my slip solution, thats more of a vinyl installers product.
and I too have the vote that painting/vinyling the dots looks like hell. Learn the blue glue method and you'll never look back.
the active ingredient in rapid tack which helps the film to stick to the matrix is just rubbing alcohol. You can make your own solution of 25% alcy/75% water and do the same thing. Peel it back, spray it, wait 20 secs and squeegee it out.
I would not advise using anything with alcohol in it if you are using SunTek. It will turn the glue into goo. :rollin
Guest tint phantom
I normally lay a 1/8 to 3/16 Bede all across depends on how much matrix is on the glass. Just like caulking a seam. be sure the matrix is perfectly dry, sometimes I heat that area up with heat gun, on the out side only so it doesn't alter the molded tint.
    rxactlite.com
    rewiredtech.io
      Tint installers, please help! Is this damage from the installer?
       Sun Pro Glass Tinting is NOW HIRING experienced Installs
    3. 4
    4. 4
    5. 4
    6. 1
      2025 kia sorento pass front window will not roll down after we tinted it. Anyone else?
    7. 0
      Join Our Family-Run Window Tinting Business in Mobile, Alabama!
    8. 1
      Newbie
