want to build my own sprayer
Guest tintgod
Guest Eclipse
Go to your local pepsi or cola distributor and ask them for a couple used stainless tanks, chances are you will get them for free. Make sure you get the hoses and hose connectors that fit on the tank.
Then you call me and I will tell you how to make the connections for both air in, and water out. I would take a few pages to explain it in here. We built a couple tanks for less than $50 each or so. :tantrum
Chances are that someone on here will have a better answer, but I had to kinda figure out how to build them on my own.
ok first you need the tank, part # 55520
now you need the valve that you hook the hose to part # 55504
now go down to orilleys auto store and get a metal bolt on air valve, drill a hole in the top that comes off and bolt it on.
all you need now is some hose and a spray handle and your in business. you can get some hose ar lowes get the reinforced type that has the cruss cross fiber in it, if you get regular hose it will burst over time.
you can get the spray hande from filmhandler or preformance tools for about 16 bucks.
I got my coil hose off the internet youi wont find that at lowes :thujmb
picture of my tank
Guest tintgod
thanks HHM..nice pics dude..that is a cool site..think im going to order the parts for that sprayer soon....figure ..why pay $160 on a tank from someone when I can build it for $50-60 :rollin thanks again....
    rewiredtech.io
    Thank you for donating to
    TintDude.com
      Under hood paint repair after Xpel removal--opinion on my idea requested.
      Geoshield C2 Carbon Ventura, Ca.
    3. 2
    4. 2
    5. 2
      Crystalline VLT question
    6. 1
      Optimal environment temp
    7. 1
    8. 2
    9. 2
    10. 8
