Easiest Blade Snapper/Disposal Ever
Posted
I've never read anybody on here doing this so I thought maybe I'd put it up.
I used to be one of those guys who snapped blades everywhere in my own shop, but they're a pain to clean up and really it's not a safe idea. Then I started snapping them off in popcans or whatever I could find (I lose stuff, so blade snapper things are out of the question, they always vanish). Anyway, now what I do is simple.
Use an empty plastic 500ml water/pop bottle (the new super thin eco-friendly ones aren't as good, since the caps even are super flimsy, but they work). Leave the cap on the bottle, slice a cut in the cap most of the way across the diameter. Now just simply shove the blade in, push the knife down, and use the cap to snap. Snapped blade taken care of. You can also open the cap and throw in any straight edge scraper blades.
Possibly a lame and obvious idea but it's what I do and they're always around.
Posted
I've cut myself trying to shove em into the dustpan before, happened once then I learned :spit
you should use a broom instead of your hand. :thumb:lol2
Posted
I've cut myself trying to shove em into the dustpan before, happened once then I learned :thumb
you should use a broom instead of your hand. :spit:lol2
You should of seen it back when I used to lick the floor clean. Ouch.
Posted
I've cut myself trying to shove em into the dustpan before, happened once then I learned :lol
you should use a broom instead of your hand. :lol2:D
Must be a Canadian thing :krazy:barf
Guest scottydosnntkno
Posted
I have the same round olfa snapper that I bought for like $2 and have filled/emptied dozens of times. Its pretty beat up, but it still works
Posted
I'm happy for you and your snapper.
Posted
:dunno :dunno We all are! :lol2
