E350 front
Guest tint51
Guest tint51
Posted
Is it possible to tint front without removing door panels... tough or easy..? :lock
Posted
We just bought one, I have not done auto in a few years, but if all cars were that simple,I would.
Guest tint51
Posted
yes its fine I do it everyday at the dealer
Yeah I did last night.. worked out fine..door seals are tight but they are deep.. so I just cut just above seal and worked out nice..
:gasp
Guest Crackz
Posted
nah we use a red devil and go below but you should be fine
Guest bnsautomotive
Posted
on the new E350 you can pull the top of the door panel back and remove the lower gasket. on all older models you should be fine with just leaving clear on and when you roll the window up and peel the clear the tint should just drop in place perfectly
