Titan Tool
Posted
The Titan Tool does anyone have one and if so is it worth adding to the tool box? I have the side winder,stroke doctor,conquer,and bulldozer already :nohit:
Guest scottydosnntkno
Posted
the titans not worth it if you already have all those others. I tried mine once and then threw it in the box.
Posted
It's also to flimsy. I broke mine first used then reshaped the tip and now it's like a bigger conquerer. You don't need it if you have all that.
Posted
I use mine for cleaning the bottom edges of deep windows. I have no use for it as an extraction squeegee as it is too flimsy other then behind a tighter brake light that a side-swiper will not get too....
It works alright sometimes.
Guest SIR TINTSALOT
Posted
I use it in combination with my side swiper. The side swiper is great but the titan gets behind tight rear decks and lights
Guest Crackz
Posted
I love the titan once you get use to it and learn how to flex it ... it works awesome I use it every day
Posted
I have had mine for 3 weeks, I like it allot. I was cleaning behind the brake light of a sentra and it cracked. maybe zola tools will replace it :poop
That's what mine did, then I reshaped the new tip and bamo! a better, but shorter Titan...
