SOLAR FREE FILM
Guest jesse1341
Guest jesse1341
Posted
IM A NEW TINTER AND I HAVE STARTED TINTING WITH SOLAR FREE BECAUSE I DONT WANT TO WASTE MONEY ON FILM ESPECIALLY SINCE IM BARELY LEARNING..IS IT A GOOD FILM TO START WITH? IT SEEMS KIND OF HARD to move once applied to the glass...also its hard not to get a crease even when being careful..is it because of the film I am having a hard time or because of my inexperience? does any one have experience with this film? any replies would be appreciated.....oh yeah my second car im trying to tint is and 06 malibu..wow is it hard...I guess because of the seals on the inside its hard to slide the film under without getting a crease.. I tried removing the door panel but I was worried to break the clips...any suggestions???????
Guest Crackz
Posted
yes its fine to learn with and you are having issues due to lack of knowledge it will get easier in time if tinting is in you
Posted
:thumb Well said! Try more slip. The only thing about learning with one film and then using another is getting used to the one you end up using......... make since? If the price is right use it but remember to get samples from all the manufactures / distributors so you will have a idea how each one differs when installing it.
Cheers and keep it up
Stan
