Low E Glass
Posted
I got a house job that the cust wants silver reflective on there low E glass at home. Whats the darkest silver reflective I can put on?
Posted
Check with the mfg.
Posted
The big question is what surface is the low E coating on? Surface 3 is where you will find issues, surface 2 should be approved by most mfg's FTG for a Silver 20 film.
Just to clarify, surface 1 is outside pane, 2 inside of outside pane, 3 is outside of inner pane 4 is inside of inner pane.
Since its a Silver 20 which is very reflective you aren't absorbing much energy so risk is lower.
But.. as TJ said, check with your manufacturer, easy answer that covers your butt too :lol
Posted
lol..you should explain that better and I would say shadow instead of shade.. when a roof line or tree casts a shadow on the window will play a big factor also
Guest vclimber
Posted
What causes thermal shock?
Guest pmuzik
Posted
:twocents It all depends on the brand of film and the angle right Mr. Wizard
Guest vclimber
Posted
You should know :krazy
Guest vclimber
Posted
:krazy
:dunno He obviously doesn't know either... not surprising. :dunno
