2002 Cadillac STS Tips?
mustangdroptop96
Posted
I did one of these a few years back and remember the seals being really tight on the sides and I know the rear roll downs shift and the back has that damn OnStar antenna. My question for you guys, do you have any pointers? If I remember right the back glass was an easy shrink but I pulled the antenna off and put it back on after but what do you guys do just cut around it? Also on those rear roll downs do you guys mark them or just cut the rear side of the glass and roll it down and finish the front cut? And theres a plastic cover over the seals but if I take that off will the rubbers pull out on the sides like the new GMS (Malibu, Impala, Grand Prixs, Etc) Any tips appreciated, thanks guys! :finger:
Guest Darknesswithin
Posted
doors are tight, I cut the front, slide it forward, tack it, cut the back, roll down few inches cut top. , shrink it, install it using a carpet shield and they are a breeze,, ,, I tape the doors as well,,
no problems on the rear glass either , pretty much a cake walk :finger:
