2010 hyundai sonata 3Rd brake light
Guest bnsautomotive
Guest bnsautomotive
Posted
Yestarday I did a sonata and my bulldozer would not fit behind te brake light so I removed and and it was a painn..
there are 2 screws that hold ot in place, theres one that you can get right where the plug for the light bulb is and the other one is hidden behing this little sticky circle covering a hole about 1" diameter.
once you remove those 2 scres then you have to pull the housing from the inside of the car and twist out the light bulb while having someone assist you from the trunk.
hope I helped someone out there. enjoy..
Guest bnsautomotive
Posted
If you take your cutters and clip the long "handle" off the socket, you can put it all back together from the inside...
Thank you! never wouldve thought of doing that, I will be sure to do that next time.
