Removing film on residential single pane glass
Posted
I have 8 large windows I will be removing tint off of and re-tinting next week. I am just curious as to what is safe: 1) can I soak them overnight with simple green covered with plastic (do you think it will help?) 2) can I use a steamer to remove the film or will it get the glass to hot?
I hate to sound like a novice but I do not normally even do these types of jobs (r & r's on residential glass).
Thanks in advance, TTC
Posted
I wouldn't try the steamer unless the glass is tempered.
Are the frames painted? I think simple green might damage paint sitting overnight.
Posted
I believe the frames are metal but they might be painted!
Posted
I just pull the tint off spray on sprayaway glass cleaner and use my 6" blade to remove, one smooth motion right to left. Just what I find the easiest for myself.
Posted
and how well does this work?
Posted
We did a few windows on this same house about a months ago and it is 20 year old auto film that tears about ever 2- 3" :beer the windows never really get warm from the sun because they are covered by lots of trees. we did tried a hair dryer and it seemed to help :lol normally we :lol from removals on homes but this is an old friends moms house.
Posted
You might try baggin em with even just soap n water. It might soften up some after as many hours as
possible. I would use white trash bags though, just in case.
Long shot for sure, but if you have the access the day before, worth a shot. good luck!
Posted
Dilluted simple pink will make it go faster. let it soak for about 15 minutes then respray and scrape. Cover any painted surfaces and wear chemical resistant gloves.
