07 Saleen
Guest kccartint
Guest kccartint
Posted
This one was a one piece bulk on the bumper and the hood was split and matte film used on the stripe. Cool car though.
And all done.
Guest kccartint
Posted
It worked pretty well. Was a little more matte then the stripe but was better then regular film or nothing.
Guest untouchable
Posted
How was the matt. I know you didn't use much but how did it seem as far as marking up. I believe thats a Parnelli Jones.
Guest kccartint
Posted
The matte film does not mark up really. I am sure it can but I have not noticed any and have stretched the film pretty hard on another install. Its a very different film then what you will be used to and is a bit flimsy and thin. Makes it rather easy to install though. I have found its best to keep to the old soap and alky solution though. Did not like the tack of the film with gel. This one was a pretty strait forward seem job. Did the sides first and then filled in the middle with the matte film.
Thanks for the comments guys. :lol
Guest XPEL Tim
Posted
Thanks for the comments guys. :twocents
Was it our Stealth film? If so, it's the same thickness as our Standard and Premium film. It also uses the same adhesive. The only reason I can imagine it felt different on tack is that it was being applied on a matte finish, which will definately have a less aggressive tack than a smooth painted finish. Hope this helps. beer.gif
Guest kccartint
Posted
Thanks for the comments guys. :bingo
Was it our Stealth film? If so, it's the same thickness as our Standard and Premium film. It also uses the same adhesive. The only reason I can imagine it felt different on tack is that it was being applied on a matte finish, which will definately have a less aggressive tack than a smooth painted finish. Hope this helps. :D
It is your film and thanks for the quick turnaround on a replacement roll. :D
