xc60
tintmor
Posted
Just done one today very easy car.No need to pull panals just pop top an take gasket out no other problems to write about.
Guest jemstar89
Posted
I did one of these last week. You are right easy car....except for the two front windows! They kicked my butt. I am going to have to redo them. They were the tightest seals on any car I've done. Should I remove the seal? What do you mean by " just pop top and take gasket out?" Thanks...
Guest james#70
Posted
remove panel mate, 2 torc screws around/under handle and them just pull panel towards you from the bottom and its all on plastic door trim clips, then pull out gasket
